pause elapsed time
Hi all,
anyone have idea to pause the elasped time express vi?
with regard
Jaxx
Message 1 of 10
(6,980 Views)
I took the subVi of the Time Elapsed VI and I've added a button control (Stop) ... if you want to included as the Time Elapsed express VI then you have to think that the value should be transfer as a reference and not as a simple variable, or it could work with a global variable.
Message 2 of 10
(6,974 Views)
Hi, Oriana...
Can I just pause the time elapsed vi but not stop it?
with regard
Jaxx
Message 3 of 10
(6,956 Views)
If you include that as subVi into a while loop then you can stop/start the timer as many times as you want ... because the controlers/indicators if are not initialised keep theires values.
Message 4 of 10
(6,953 Views)
Hi, Oriana...
You help me so much~ Thanks for your reply 🙂
Best regard
Jaxx
Message 5 of 10
(6,938 Views)
 Hello Oriana,
I have the same Problem like @. I want to Pause the elapsed time express VI. Can you give me an example with the outer while loop? I use LabView 8.5.1.
Ice1984
Message 6 of 10
(6,490 Views)
Fins solution here
Message 7 of 10
(4,610 Views)
@sardarsree wrote:
Fins solution here
I am sure RafelK will be happy to find the solution after 8 years 😉 Specially since he was last time logged in in 2014...
By the way, I do not like the solution from the CLD preparation material which you just attached. Much more compact to program your own FGV with shift registers.
Message 8 of 10
(4,597 Views)
Can anyone help me to understand the meaning of True case function of pause mode?
Message 9 of 10
(2,764 Views)
When paused, keep track of how much time in Pause so it doesn't affect the total elapsed time when calculated from Now - Start Time.   ???
Message 10 of 10
(2,752 Views)
