04-14-2011 01:15 AM
I want to pass an array of strings to a teststand to a labview dll, and get back another array of strings from the dll to teststand. I have tried both standard calling convention and C calling convention by compiling the dll. In TestStand by specifying the module, I tried all the 4 possibilities to handle the array of strings (C String, Unicode String, C String Buffer, Unicode String Buffer). It doesn´t work, I get always an error from TS: -17502, System Level Exception.
It would be easy to pass the TS Sequence Context to the dll, but I don´t want to do it, because use the dll outside teststand too.
Mitulatbati
04-18-2011 08:22 AM
Hello Mitulatbati,
Did you have a look at the following Link? This is an example which, I guess, will exactly show your application:
http://zone.ni.com/devzone/cda/epd/p/id/134
Also the following Link might be interesting for you, even the last post. IOt telles you that you can't use char as data type:
I hope this helps.
Best Regards
Regina
AE Germany
04-18-2011 08:46 AM
Yes, it is working wih the attached dll, which is written in c (or CVI). But I want to change string arrays between TestStand and a LabVIEW dll. This doesn´t work with the settings, shown in the linked sequence.
04-28-2011 01:50 AM
Sorry for my late reply.
I tested your configuration as well and to be honest: It doesn't work either.
I also could not find any possibility to do that. Using complicated data types for DLL can always be a problem.
Does your dll with string array passing work on the other program you mentioned?
I am sorry for having no soltuion for you at this moment but I have got a suggestion for you:
You could use the function flatten to string to pass the string to TestStand. Then you don't require an array and this should work for you.
Best Regards
Reigna
AE Germany
04-28-2011 02:01 AM
Hi Regina,
thanks for your post.
I have solved it on a different way. I create a comma separated spreadsheet string from my string array, and I pass only this simple string. In the dll I rebuild the string array, and it´s done.
regards
Mitulatbati
