Hi gdutson:
Ok, I've seen the screenshot and I think I have found some issues on
the VI. You're creating the cluster correctly, but only for one row of
the array. If you want all the data to be inserted in the table you
must create a cluster for each row in the 2D array. It may be a good
idea to do it in a for loop.
And about the error, well I currently don't have the Database
Connectivity Toolset but searching in the web I found out that you need
to wire in the
columns input of the VI an 1D array with the
column names that match with the elements that the cluster contains. As
I see in the screenshot, you're wiring an empty array to the columns
input, and that's why you're getting the error message. Modify the
array constant so it contains the correct column names and the error
should dissapear.
Robst - CLD | |
Using LabVIEW since version 7.0 |
