08-25-2014 11:10 AM
I took a certified driver file, put it in user.lib, rename the project file and containing folder. I opened the renamed project, change the VI icon colors of all project files, relink all missing files to user.lib directory, saved all the files, saved the project. Then I restart LV2014 and no menu appear in Tools User Libraries.
Has anyone tested this using LV2014 or older?
Rich J
08-25-2014 11:52 AM
Try editing your palette. Tools->Advanced->Edit Palette Set.
08-25-2014 12:18 PM - edited 08-25-2014 12:24 PM
Thanks for the fast response.
I fixed it by deleting the menu (*.mnu) files in all (sub)folders and restarting. Those menu files were for the original certified driver files (pointing to the original VIs I keep in instr.lib).
Rich J
08-26-2014 02:42 PM
Just an FYI there is a Refresh Palette funciton under the Application Control >> Palette Editing which can be used for testing. It won't refresh the tools menu but it allows you to modify files and MNUs in the user.lib then call that refresh to see if it worked without having to restart LabVIEW.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
