07-07-2015 04:44 AM
Hi...
I tried to build triggered oscilloscope on PCI 6014 for educational purpose. First I build nontriggered Oscope13.vi and it works for me satisfactory. I can change oscillograme with time/sec and volts/sec, and measure values with cursors.
Then I want to trigger that Oscope13.vi with Analog SW Trigger.vi that I found in Cont Acq&Graph Voltage-Analog SW Trigger.vi example as subVi.
I built Oscope14.vi.
Now nothing works as i wanted. Time controls don't change oscillograme and it blinks (some kind of jitter).
Please, can anyone help me to get my nontriggered Oscope13.vi work also in triggered mode.
I work on LabVIEW 8 Full Developement.
Computer: Intel Pentium 4 CPU 2,00 GHz 1 GB RAM
Thanx in advance.
Damir Mileta
07-08-2015 09:05 AM
Damir,
first of all, the 6014 is a multifunction data acquisition device, not an oscilloscope.
I don't know where you got that example from as it is not following common implementation style guides.
That being said, i see that your DAQmx read returns an array of waveforms. This datatype contains the raw data and timing information. Your conversion of this to a 2D double array removes that timing information. So i assume that your waveform scaling functions runs rampart and messes things up.
Norbert
07-08-2015 04:10 PM
