optimization for conversion
I have the following VI
It runs fast enough on a fast PC (duo core 2) but it doesn't run fast enough on my laptop. Is there a way to optimize this?
Thijs
(2,661 Views)
Accepted by topic author ThijsBoeree
Thijs,
This is about ten times faster:
Polymorphism, especially for arrays, can be your friend.
Lynn
(2,642 Views)
Oke, i'll see it tomorrow, i am on my way home now...
Best regards!
Thijs
(2,635 Views)
Thanks!
Can you also explain why it is faster? Do you have an article about this? I am very interested!
Thijs
(2,615 Views)
Hi Thijs,
it's faster because:
- it uses polymorphism of the "Split Number" function to work directly on array data
- thus the compiler may use some SSE optimization (?)
- it doesn't use a BuildArray node as your version: the appending output tunnel of your FOR loop is nothing else than a shift register with a BuildArray node as was used for the purpose in older LV versions...
(2,609 Views)
@GerdW wrote:
Hi Thijs,
I think that the main factor here is the avoidance of a Build Array node inside a loop by using the Interleave 1D Array node instead. Anything else might or might not add a few microseconds to the mix. Could be easily tested by removing the Build Array Node in the original VI and creating three 1D arrays on the loop boundary, then use Interleave 1D Array to combine them together. Certainly the speed difference is then much smaller and probably almost nihil.
Rolf Kalbermatter
My Blog
(2,606 Views)
Thank you to GerdW and rolfk for contributing explanations while I was sleeping.
Lynn
(2,587 Views)
