opening .ncl file
I created a CAN log file from the Create Logfile from Channels.vi and now I want to open it and pass it through a compact RIO with a NI 9853.  I am using the open/create/replace file function but I keep getting error 7.  I have verified the path multiply times.  I have it saved to the c drive such that my path is c:\logfile.ncl.  What could be causing this?
(1,962 Views)
Where are you trying to open the file?  On the compact RIO or your PC?
Where is the file located?  On the compact RIO or your PC?
EDIT:  Continue in your original thread since you are already getting help there.
(1,959 Views)
