04-20-2005 02:48 AM
04-20-2005 02:07 PM - edited 04-20-2005 02:07 PM
Message Edited by jhoskins on 04-20-2005 03:08 PM
Message Edited by jhoskins on 04-20-2005 03:09 PM
04-20-2005 02:48 PM
12-14-2005 05:07 AM
These programs are just fantastic... I have started learning active-x, but I am confused where/how to use the property node and where/how to use invoke node efficiently so that I customize the existing application according to my usage.
please tell me where will I find the tutorials related to it...
Thanks and Regards
Sreedhar
12-19-2005 04:10 AM
03-22-2016 04:01 AM - edited 03-22-2016 04:03 AM
Hi folks,
I am new to the report generation. I don't know how to get the reference(word._Application)
Can anyone please explain the steps how to get that reference?
I attached the vi pic.
Thanks & Regards,
Shree
03-22-2016 10:07 AM
@shree_bala wrote:Hi folks,
Thanks & Regards,
Shree
1- Put the Automation Open vi on your block diagram. (Form the Connectivity -> ActiveX palette)
2- With the wiring tool right click on the Automation Refnum input
3- Go to Select ActiveX class -> Browse...
4- In Type Library select Microsoft Word 14.0 Object Library Version 8.5 (this is the version installed on my pc, yours may be different)
5- In the Objects section check Show Creatable Objects only (optional, it will shortened the items list)
5- Select Application (Word.Application.14) (for my installed version)
Ben64
03-22-2016 12:46 PM
Hi Ben64,
Thanks for your fast response.
I couldn't find the "Microsoft Word 14.0 Object Library"
Whether the library is same for Microsoft Office 2013?
03-22-2016 12:52 PM
03-22-2016 12:58 PM
I found the version 14.0 but couldn't find the higher version for the object library.
Can you give link to download the object libraries?
