Hi I have modified the example_launch.vi and try to open the same subvi (test_run.vi) twice now. I have set the test_run vi to "reentrant execution" and expected that this should create two result files. but there's still only one instance opened and one result file created! What's wrong?
Does anybody knows what happens when I create an executable? I guess the loaded subvi will also be *.exe. Or does this type of programming only works with *.vi. Because I made an executable with test_run.vi and tried to run it again. And nothing happened... (The test_run.exe works fine when running in standalone.)
