01-28-2008 02:55 PM
01-28-2008 03:47 PM - edited 01-28-2008 03:50 PM
Hi Reza_Sed
this link describes where the information about the default email client can be found: http://www.wintotal.de/Tipps/tipp1201,urubrik4.html.
It should be possible to load this default program with "SystemExec.vi". I think it could be one solution for you. Hope it helps.
Mike
01-28-2008 05:10 PM - edited 01-28-2008 05:10 PM
01-29-2008 07:45 AM
06-16-2015 05:32 AM
this seem does not to work with labview 2014.
Is there another solution?
best regards
Manuel
06-17-2015 04:57 PM
Hey this might be an alternate solution that you're looking for
How Can I Send Email from LabVIEW via a Secure SMTP Server such as Gmail?
http://digital.ni.com/public.nsf/allkb/484272384C2960AA8625749E006512EE
06-18-2015 01:04 AM
No,
Thanks anyway
i would open defualt client mail to send specifics e-mail.
i write only email address to destination
Manuel
06-18-2015 07:14 AM
How does sending an email through Gmail satisfy the need to open the default email client?
I tested the Open URL method in 2013 SP1 and it works, I tried it in 2014 SP1 and it doesn't both 32 bit in Windows 7 x64. There are likely other ways to do this, possibly involving reading the registry, or creating a email file that is then opened.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
06-18-2015 07:26 AM
Okay it wasn't hard, attached is a VI that runs the default email client by reading the registry which I got from here.
http://stackoverflow.com/questions/1119745/find-default-email-client
12-21-2020 11:09 AM
I know this is an old thread but I found this thread when facing the same feature request, and I found this more "generic solution" which is not using the registry (supports adding e.g. recipient, subject, body message). Could be useful is someone else is looking for this functionality.
