open Excel file from front panel
I have been trying to open an existing excel file to open from front panel button.....however by looking in the forum I found two examples....attached.....one is doing with word document and other notepad.....however I am unable to do with excel.....
In second example which use Sysexec.vi....I tried to enter the path of excel file....but it doesn't open...however same file opens when I write it to "Run" in windows vista.....
Advise...
(4,648 Views)
maybe this could help:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(4,644 Views)
Thanks,  Harold....
                          But I was wondering that if this can be possible using either of two vi attached in my first post....especially using sysexec.vi ....actually I am not geeting commandline to enter in the vi...
(4,636 Views)
what command should be given to sysexec.vi to open microsoft excel file????
(4,608 Views)
Accepted by topic author 26314362
I got the solution.....using sysexec.vi and command line prompt..........
 Smiley Happy
Thanks........
(4,574 Views)
So how do you do it?
CLAD
(4,205 Views)
first try to open excel from command prompt....if you find path  then give same path as a input to sysexec.vi...
(4,189 Views)
