05-26-2016 02:49 PM
i have some problems with buttoms. I use the same buttoms for each event in event case but i dont know how to realize it.
now it work with 50% chanсe. When i star solution#1 (Dopller effect->Solution#1) a than after that Solution#2 butoms stop working as it must be.
i think that problem in that cases. Thank you.
Solved! Go to Solution.
05-26-2016 02:57 PM
Generally you should have only one event structure in a VI. OTherwise you run into exactly the problems you have encountered.
Look at the Producer/Consumer (Events) design pattern which comes with LabVIEW. It shows a method of having a single loop with one event structure to respond to all front panel events. Then it sends messages via queues to other loops where the actions take place.
Lynn
05-26-2016 03:55 PM
