09-30-2012 03:42 PM
I created a cluster constant containing 6 booleans with descriptive labels. When I made it a typedef the appearance changed to this:
Now I have obese booleans! Anyone else encounter this?
The width of the booleans seems to be related to the length of text in the label.
I can still click on the booleans and change their values. I can change to the icon view and see the normal icon, but when I change back, I get the fat booleans.
I had to delete the cluster and place a new instance of the type def to get back to the normal appearance.
10-01-2012 07:45 AM
What version of LabVIEW are you using? I seem to remember a corrective action report about this issue awhile back, but I believe it has been fixed. Let me know and I will try to track it down.
10-01-2012 07:51 AM
Sorry, left out the important details. This happened in LabVIEW 2012 (Version 10.0f1 32-bit) running under Windows 7 Professional, 64-bit.
10-01-2012 09:39 AM
Thank you. We found this internally a few months back, just after the release of LabVIEW 2012. It is CAR 361839 if you want to track it.
10-02-2012 09:07 AM
With scripting, you can make your boolean constants any size (and any color).
