05-24-2008 12:49 PM
05-24-2008 01:45 PM
The comparison can be done using a case structure (you can feed the numeric into the selector and use some syntax, available in the help, to select ranges).
The coloring can be using a property node. Right click on the control or the terminal and select Create>>Property Node. Then select the Numeric Text>>Text Colors>>BG Color property.
05-24-2008 06:31 PM
labtech5555 wrote:
If the output of x+y >5 then i want the output text box to turn Red.If the output of x+y>5 then i want the output text box to turn Green.The default colour should be white.
05-25-2008 01:48 AM
Ah, those pesky details...
altenbach wrote:
OK, this makes no sense at all. If x+y > 5 it cannot be red and green at the same time.
