08-29-2012 12:09 AM
I want to ask a question if DAQ assistant is needed in a system for reading the input.
08-29-2012 12:35 AM
Depends - From where you are reading the input and what hardware you are using for that .
You will need DAQ if you are using one of the DAQ cards from NI for measurement.
Regarding DAQ assistant , it helps to configure the DAQ device.Using DAQmx you can get flexibility to program DAQ devices
08-29-2012 12:37 AM
Okay,thanks alot 🙂
