Reply
normalise array to values between 0 and 1?
Is there are .vi in labview that will allow me to normalise an array of data to values that are between 0 and 1? if not, does anyone know the calculation that will allow me to do this?
Message 1 of 6 (9,164 Views)
Reply
Re: normalise array to values between 0 and 1?
ok nvm, worked it out. its a + (x-A)*(b-a)/(B-A) where:
A minimum of dataset
B maximum of dataset
a is from where you would like normalised data set to start
b is where you would like normalised data set to end
x is the value you are trying to normalise
found it at this website http://www.howcast.com/videos/359111-How-To-Normalize-Data
Message 2 of 6 (9,151 Views)
Reply
Hi LVStudent,
To normalize a waveform you can run a search for "Normalize Waveform.vi" or in the function palette-->Programming-->Waveform-->Analog Waveform--> Normalize.
Hope it'll let you avoid implementing this: a + (x-A)*(b-a)/(B-A).
Message 3 of 6 (9,139 Views)
Reply
[ Edited ]
Firstly, normalize waveform will scale a waveform to [-1..1] and not [0..1] and the OP asked for an array operation, not a waveform operation. Both are incorrect answers.
Here's how you would scale an array from 0..1. If you want, you can turn this into a subVI. Smiley Happy
Message 4 of 6 (9,129 Views)
On a side note, I wish NI would get their terminology straight here. For example:
  1. Normalize waveform: scales a waveform from -1..1
  2. Normalize VI: normalizes an array so the statistical profile has a mean of 0 and SD of 1.
  3. Scale VI: scales an array from -1..1.
  4. Waveform scale and offset: Does again something entirely different.... equivalent to linear evaluation!
1 and 2 are very different, but have similar names.
1 and 3 do basically the same, but have different names....
etc.
sigh!
Message 5 of 6 (9,111 Views)
Reply
After you posted your first response, I looked up the algorithms/formulas in use and 1&2  are, indeed, very different.
How innocent of me to think that they are all the same....
From my experience, which isn't much, we use #2 and not/never [-1...1], but I guess it depends on the application/discipline.
Message 6 of 6 (9,108 Views)
Reply
