no me funciona subvi
en la secuencia del subvi  funciona bien pero al momento de llamarlo a otro programa este ya no funciona
(2,510 Views)
una imagen
(2,509 Views)
(2,507 Views)
The way your subVI is set up  it will be called from your main VI,  run until it completes, and then return control to the main VI while passing the final values of the booleans.  The intermediate on and off states inside the subVI will not be passed to the indicators on the main VI and I'm guessing this is the "error"  you're reporting?
The way to have a subVI affect a control/indicator on the caller's front panel is to pass a reference to the caller's front panel indicator to the subVI and use a "value" property node inside the subvi.
Try the attached to see the concept and adapt it as you need.  There is a bit more information here and here.
(2,484 Views)
Buen día RT23i.
Lo que menciona Zwired1 tiene razón, dependiendo del comportamiento de tu SubVI de forma individual es como se comportará en el VI que hace uso de este (Calling VI), al momento de llamar tu VI te arroja algún mensaje de error? Se queda trabado? Como estas mandando llamar tu SubVI?
Saludos!
Luis CT
(2,442 Views)
