09-12-2006 07:23 PM
09-12-2006 07:47 PM
Ooops,
Is very early in the morning here, I meant I am using ' Read and Parse' not Query and Parse,
sorry
09-14-2006 05:40 AM
Hi Mexa,
Can you post the vi your having problems with?
Hannah
NIUK & Ireland
09-14-2006 09:54 PM
09-18-2006 03:15 AM
Hi Mike,
I'm not sure what the issue is, as the data is showing up in the instrument i/o assistant. Are you saying that when you run the vi it doesn't pass the value of one of the parameters ('vol' or 'temp corr') into the indicator on the front panel? If this is the case, what happens when you run the vi with execution highlighting on? Or if you probe the wires, can you see the values there?
What is the smoke meter that you are trying to communicate with, do you have a programming manual for this?
Hannah
NIUK & Ireland
09-18-2006 03:04 PM
Hi Hannah,
Yes, the data does show in the i/o assistant, but the second value will not show in the front panel indicator.
I ran in execution highlight and with probes on both outputs, the result is the same. The first output contains the data "Temperature corr.factor : 62548" and this is in the probe as well. But the second probe and indicator remain blank.
The unit is an AVL 415 smoke meter and we do have a manual for it. When connected via. Hyperterminal and a 'LIS' command sent to it, it responds with -
Volume corr.factor *1000: 878
Dead volume [ml] : 44
Ambient pressure [mbar] : 980
Nominal volume [ml] : 1000
Sample time [0.1s] : 60
Number of samples : 3
Auto Range min.vol. [ml]: 500
Auto Range max.vol. [ml]: 5000
Extended Purge [0.1s] : 0
Trigger delay [0.1s] : 0
Tolerance [0.01FSN] : 20
Printout: normal
Printout: English
(The values might be different, as is another unit) I am using the smoke meter as a practice and wish to check and display the internal parameters quickly. In the I/O assistant I can put multiple 'Read and Parse' after writing 'LIS'. each one returns correct values as above in order. But only the first one is shown on it's indicator.
Hope thats clear?
Mike
09-19-2006 05:59 AM
Hi Mike,
mmm, seems very strange!
One thing to check would be to see how LabVIEW works with the lower level vi's, it could be something that has been misinterpreted by the instrument I/O assistant. What you can do is right click on the express vi and select 'open front panel' then this will convert the instrument I/O assistant into the lower level vi's which are used by LabVIEW. This will build a subvi in its place. I would do this and then run this sub vi with execution highlighting on, this will tell you what is read back from the instrument, and what LabVIEW is doing when its parsing the data - which at the moment, it seems like its removing the data from the buffer.
Do this on a copy of your vi, once you've done the 'open front panel' option, you wont be able to return to the configurable express vi in this instance.
Try this and let me know how you get on.
Hannah
NIUK & Ireland
09-19-2006 02:49 PM
Hi Hannah,
Thanks for your time, is appreciated
I have done as suggested and attached the vi.
The problem is the data comes out of the first VISA read and parses correctly and displays, the data also comes out of the second VISA read correctly, but does not come out of the 'Match Regular expression vi' which is supposed to remove the delimited unparsed text.
Mike
09-20-2006 07:08 AM
Hi Mike,
OK, looks like we're getting somewhere now. It seems like something has gone wrong either with the way the instrument i/o assistant is building its code or one of the functions isn't working as expected in LabVIEW.
I've modified the code slightly so that it displays all the strings its receiving so its easier to see what is being returned where. Can you run this vi for me, and then once its finished set all the controls so that their current values are defaults. You can do this from the Edit menu, by selecting 'Make Current Values Default', can you then save it and post it back on this forum, this way I'll be able to see the strings, and I'll modify the vi so that it works correctly.
Hannah
NIUK & Ireland
09-20-2006 02:17 PM
Have attached run and defaulted vi.
Cheers,
Mike
