06-02-2015 02:18 PM
I downloaded LabVIEW 2014 SP1 for evaluation, and need to create simulated devices to follow the tutorials. When I open MAX and right-click on Devices and Interfaces, there is no Create New option, either in a pop-up menu or in the Devices and Interfaces display. Expected Create New… » Simulated NI-DAQmx Device or Modular Instrument. NI DAQmx is installed. Has anyone encountered this or have a suggestion? Hope to get this running before the evaluation period is up.
Solved! Go to Solution.
06-02-2015 03:05 PM
You are trying to find this?
06-03-2015 02:29 PM
Yes - that is what I was expecting. I found that NI DAQmx was not properly installed, downloaded the latest and it started working. Thanks
06-12-2015 01:57 PM
I just now ran into the same problem. No Creat New option...
I will try to re-install...
Regards
