11-04-2014 11:30 PM
For one of my application, i am planning to use NI-USB 5133 card .
I need a small information regarding this card. Is it possible to access all the controls & monitor the data by using the Driver provided along with this card with out writting any LV application. I just want to use it as an traditional oscilloscope to monitor the data manually in my laptop. if possible please share the screenshots of the driver
Thanks in advance
Naresh
11-04-2014 11:34 PM
well there is a soft front panel for that device
11-04-2014 11:40 PM
Thanks for your information.
can you please share me the screenshots if possible.
Naresh G
11-05-2014 12:16 AM
11-05-2014 12:37 PM
Generally all NI hardware has some kind of test panel in MAX (Measurement and Automation Explorer). There are a few exceptions like FPGA cards which need functionality programmed into them. Startup MAX go to your device and right click it, and launch the test panel. Sorry if your device doesn't have one I've never used that particular device. This is of course only available once the drivers that your hardware came with are installed. Without this your OS won't even be able to see the hardware.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
