02-25-2015 09:18 AM
Hi all
I'm having trouble importing my NI MAX setting , and without this my VI's doesn't work.
Here the error message (i've already tryed to re-install the niDaq drivers and NI max and i've updated all)
Date: 19/02/2015 17.31.14
User: matvil
File: Y:\13-SOFTWARE\NI_labview\Ni max setting\RIPRISTINO_wxp152.nce
File version: 5.3
MAX version: 5.3.1
Importing...
NI IVI Compliance Package 4.5:
DriverSession "ni5442"
DriverSession "ni5441"
DriverSession "niDCPower"
DriverSession "ni5431"
DriverSession "niScope"
DriverSession "ni5406"
DriverSession "NI PXI-4110"
DriverSession "ni5422"
DriverSession "ni5404"
DriverSession "ni5451"
DriverSession "ni5421"
DriverSession "niFgen"
DriverSession "ni5401"
DriverSession "ni5402"
DriverSession "ni5412"
DriverSession "ni5411"
DriverSession "ni5450"
NI-VISA 5.2:
General Settings
LPT1.4 (ASRL11::INSTR)
VISA Alias (LPT1)
VISA Alias (COM1)
Port Settings (COM1)
Port Settings (LPT1)
VISA Server
Security
NI-DAQmx 9.5:
-229750
Internal Software Error occurred in MIG software. Please contact National Instruments Support.
*** Import FAILED ***
NI-DAQmx 9.5: error code 0x80004005
02-25-2015 09:42 AM
I found a link to a kb article talking about MIG errors. It may be relevant: Why Do I Receive Error -229771 at DAQmx Start Task.vi?
It might help to try importing MAX settings as a different file type. This would mean re-exporting from the original system. Choose one of the INI file types instead of the .nce standard type.
The INI file is plain text, and you can manually remove parts of it that may be causing the crash. ( I've done this before successfully )
03-24-2015 02:53 AM
I understand but , i can't recover my old setting, i can't save now in another format because the NI MAX setting are wrong
03-25-2015 05:36 AM
Error When Importing Measurement & Automation Explorer (MAX) Settings
You have to Re-Export the settings... i think there are no other solutions.
