ni 9219 Analog input not working correctly
I have connected Analog voltage of 5.2v to Ni 9219 CH1, Pin 4 & 6. but the reading i am getting on labview is 1.8v.
please find the attached screen shot.
Note: in the screenshot, block diagram, CH2, CH3, CH0 are not connected.
(2,800 Views)
You should attach your actual VI, a screenshot will not help others to help you.
By the way, you do not need to use your mobile phone to make a photo, any OS can do a screenshot 🙂
http://www.howtogeek.com/226280/how-to-take-screenshots-in-windows-10/
(2,764 Views)
hi , thanks for response.
i have attached the VI.
PC was not connected to network that time, so used mobile:P
(2,754 Views)
Hi Rudra,
attaching a FPGA VI without the project it is used in is senseless as all FPGA definitions/properties are missing…
How did you configure your NI9219 module?
For measuring voltages you should use pin 4 & 5 - atleast that is what the manual says… (RTFM!)
(2,747 Views)
