.net container background color
I am using .net control(DataGridView) in my LabVIEW application and am using .net container to display the datagridview. The issue I am having is that I am unable to change the background color of the .net container. I need to have a white background but using the tools pallete I am unable to set its background color. Is there any way to set the background of .net container?
Ritesh
(2,767 Views)
Accepted by topic author LVCoder
Everything inside the container is drawn by the .NET control, so the responsibility is there. A quick look shows that the DataGridView control has a BackgroundColor property. Did you try calling that property to set the color?
___________________
Try to take over the world!
(2,745 Views)
Thanks, that solved the issue.
(2,716 Views)
