need simple symbols in string ans table such as less than or equal to (≤)
any ideas?
Message 1 of 12
(3,690 Views)
Hi Aaron,
why not use those "simple symbols": <, >, <=, >=, <>, ==…? 😄
Can you show a (real-world) example of your "string ans table"?
Message 2 of 12
(3,687 Views)
I can't use <=, because end users will not understand it.
Message 3 of 12
(3,649 Views)
If end users don't understand that, then I'd argue they would need training, or they aren't going to understand the 1-character version either.
One possibility is that you use the Symbol font within the table. <= is code 163 decimal (xA3).    >= is code 179 (hex B3) and <> is 185 (hex B9).  The tricky part is that you'd have to mix and match fonts within the cells of the table so that only that character is Symbol in the event that other characters need to be letters.
Message 4 of 12
(3,642 Views)
Here is an example of what I have inherited, and the customer doesn't want me to change the table indicator.  My customer's customers will not understand (<=) as shown here:
Normally I will get a degree symbol from MS Word and it copies in just fine and displays just fine.  But, if I do the same thing for a less than or equals (≤) OR a greatert than or equals (≥), then it shows as a question mark (?) as seen here:
Message 5 of 12
(3,638 Views)
I have no control over the customer's customer training.  Is it possible to change the font between characters in the cell of a table?
Message 6 of 12
(3,635 Views)
It's not trivial to do. Here is a simple implementation of RavensFan's suggestion. It substitutes xA3 for a single instance of "<=". It's not perfect but it could be a starting point for your code. I'll leave all the finer details for you to figure out.
Message 7 of 12
(3,616 Views)
So it is possible to change the font per character within a string.  I'll give it a shot.  Hopefully this is possible within the table as well.  Thank you both for the replies!
Message 8 of 12
(3,607 Views)
From my quick test, the answer is no.  I tried to change just a couple characters within a cell, but the entire cell changed to a different font.  Other cells in the table kept the font.
If you can find a font that that contains those symbols, as well as all of the normal letters and digits and puncuation characters you might need, then you can set your table to that font.
But your customer has control over their customer's training.  I just think they need to readjust their thinking.  Anyone who knows anything about greater than and less than symbols (elementary school age kids and above) ought to be able to easily figure out that >= and <= mean the same thing.
Message 9 of 12
(3,605 Views)
Jamiva,
What you show works for a string.  However the request was to do something like that within a table.
Message 10 of 12
(3,601 Views)
