01-23-2014 11:09 AM
hi all,
i fired up my myRIO today after being filled with confidence on the real time 1 course and looking at a bunch of examples.
whats scuppered me is i cant find any of the vi's in the functions pallet, i thought they would be in the same place like the DAQmx stuff but no bannana!
i just want to write a few simple VI's to play at some anaglog/didtial io and bosh im stuck!
please point to the pallet and save my sanity!
(i find it quite funny really as i suspect they are right there infront of me)
01-23-2014 12:21 PM
I don't have a myRIO so my answer may not be correct. But I would first start in the Help >> Example Finder and search for myRIO and see what there is for basica connection and I/O. Then I would go to the functionals palette, and click search then search for myRIO which will hopefully show you where in the palette is the myRIO functions.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
01-24-2014 02:26 AM
good call, i tried that.
using an example from the project essentials guide i can find the names of what im searching for but then when i go to a blank VI to start writing my own i i cannot find them in the palet even if i search the name.
it looks pretty uch like a DAQmx VI and from the couple ive seen the logic looks a bit like daqmx too.
if i use context help and clik the detailed help link it shows myRIO in the help its the next one down from myDAQ. it explains the VI but then when i click the "show on pallet" link i get an error saying
object not found possible reasons include
1. the object might exist in a different pallet view
2. the object might not be supported on a target in the project explorer window
3. ....... something to do with expired licence
4. bject uses functionality not supported on the operating system
01-24-2014 02:42 AM
Hi Dombanks,
Did you create a new project?
Did you include the myRIO as target in the new project?
Did you create the fresh VI for that target?
Why don't you show a picture of the block diagram when you talk about some "unknown objects" without naming them correctly?
02-17-2014 11:29 AM
LabVIEW has developed a palette with express duties to begin work on this device, there are few examples of Myrio in the form of examples, but I'll leave a link to the academic community of national instruments, you can search by category and you will find examples developped, Greetings
https://decibel.ni.com/content/community/academic/products_and_projects?view=documents#/?tagSet=1869
06-20-2014 09:40 AM - edited 06-20-2014 09:46 AM
Dear all;
i have a labview 2013 software installed in mypc ,but it have no myRIO control and function palette.even when i am try to download 2013myRIO.exe i have encountered an error.what shall guys?
thank you
06-20-2014 12:01 PM
06-20-2014 12:54 PM
@samuelaa wrote:
Dear all;
thank you
First the really obvious question: Did you install the myRIO version of LabVIEW that came with your myRIO?
06-21-2014 06:25 AM
06-21-2014 06:36 AM
