03-19-2015 01:28 PM
I am quite new to labview so hope someone can help. What I am doing is to use NImyDAQ to connect 8 different sensors and show the output on labview. Since the myDAQ does not have enough input for 8 sensors, so I am using two 8 bits multiplexers to solve it.
Here is the question. How do the circuit draw in the labview which will make it works? I want to make an drop down button to select which sensor is connected and shown, therefore I need to output boolean value (0,1) to the digital input/output? I have try using case structure but seems difficult for me. Is there any example similar to what I am doing?
03-19-2015 02:28 PM
03-19-2015 02:51 PM
What you mean by skiping the DAQ Assistant? Can you make a drag and drop diagram for an example? I have no idea how the drop down menu giving out numerical value then goes into the Digital input in NImyDAQ.
03-19-2015 03:35 PM
