Each time I close LV7 on my WinXP machine, I get the following error:
"The application or DLL C:\Program Files\National Instruments\MAX\mxwOTask.dll is not a valid Windows image. Please check this against your installation diskette."
I recently had to image my old hard drive and transfer it to a new one, as my old hard drive was in the process of dying. Some stuff with LV apparently got screwed up in the whole transfering process, and I had a handful of these types of errors in LV7 & LV8 (I have both installed on my machine) and probably in DIAdem and other stuff. However, by using the repair feature in the installer, I have been able to successfully get rid of all the problems (as far as I know)
except the one mentioned above. I have tried repairing
both the installation of LV7
and the installation of MAX (not to mention LV8)... multiple times! Any ideas why I can't shake this problem? Any ideas on how to fix it?
P.S. - Yes, I've run chkdsk /f on my drive.
Nick
"You keep using that word. I do not think it means what you think it means." - Inigo Montoya
