multiple outputs with two PCI
Good Morning, my name is Leonardo, i'm an electronic engeneering student and i've started for the first timo to work with CVI. I would like to generate multiple outputs, and i have two PCI 6733, I need to separate my 16 outputs in two different PCI. My question is, can i use taskhandle as an array of data by specify inside of it the two different PCI, or i need to go with multithreading and so run another thread which d the same thing as the first but into the second PCI? how can i synchronize the two PCI so they work simultaneously?
(I already have a program which comunicates with one PCI 6733 I only need to modify it, but i've started to learn cvi since few weeks ago and I've still some problems)
thank you for your kindness,
Leonardo Vencato
(2,424 Views)
Hi Leonardo,
there's a special CVI forum
How to synchronize several DAQmx channels and devices is explained in the examples (atleast those for LabVIEW). I guess CVI also comes with an example finder?
(2,420 Views)
