11-21-2012 07:28 PM
when i run a circuit in multisim and what to watch the results through a multimeter what are the settings for the resistance, ampere, and voltage. espcially for the internal resistance because it seems like im not getting the correct readings because it is not programed correctly. thank you for your help
11-21-2012 11:31 PM
You'll have better luck if you post your question in the Circuit Design Suite (Multisim, Ultiboard) forum.
(Be sure to properly capitalize your message to make it easier to read.)
11-26-2012 03:26 PM
Hi Afaro,
When you expand the multi-meter, there is a "set" button; click on it and you will see the multi-meter internal resistance.
