multicolumn listbox
HI anyone please help me, how to get an output array value and put in the multicolumn list box? Sorry , it look like very simple but I don't know about it. Thx William Lee
(3,397 Views)
Accepted by topic author williamlee1982
Hi William,
Right click on it>>create>>property node>>item names to create a property node of item names.
If arraw of item names property is on the right, right click on it>>change to write.
Item names accept string data type.
Therefore, if you intend to write a number to it, you must use a function to convert numeric to string first.
If you've just a 1D array, wire it to build array function to create 2D array supporting by item names property.
Regards, Kate
(3,391 Views)
thx kate
(3,351 Views)
HI kate,
Just want to convey my thanks for solving the puzzle for multicolumn listbox. I just spend couple of hours trying to go through examples of listbox but no luck. I tried your solution, it flies in one shot. Thanks again.
Hansa
(3,242 Views)
Kate, can you elaborate on this a bit more for a begginner? I'm hoping to be able to write to a listbox and use it like a data table, but I dont quite follow your explanation. I'm logging numerical data, and my column headers are #, relative position, measured value, and comment. All of my values will come from an array, and comments can later be added. I'm also looking for a way to export the data from my listbox to a spreadsheet or text fil. Thanks for your help!
(2,344 Views)
