03-08-2015 11:15 PM
Hello everyone.
I'm using the multicolumn listbox.
I want to the multicolumn listbox like excel
I want to the multicolumn listbox each row, column by control
and each graph, each sum etc...
Seek advice.
I appreciate that.
03-08-2015 11:34 PM
I see you have a multicolumn listbox in your VI. What is your question?
Where does Excel fit into this?
03-09-2015 12:02 AM
Want to use the columns and rows of a multi-column list box as Microsoft Excel.
For example, the sum of the daily dose, Number of Rows, Graph of the month dose...
Want to be represented under a multi-column list box.
Best regards.
03-09-2015 07:50 AM
A multicolumn listbox is a 2-D array of strings.. Break out the columns you want (Index Array). Convert the string data to numbers (String to Number conversion). Then sum the array (Add Array Elements).
03-10-2015 06:27 AM
Thank you for your response.
There should not be making reference to.
I counted the number in the first column came out 16.
Not even sum columns.
LabVIEW is very hard for me.
03-10-2015 07:43 AM
I don't understand your last message.
Are you still having problems? Attach your latest VI and give a clear explanation of what it is doing wrong.
03-10-2015 08:46 PM
Thank you for your interest.
I have attached the file.
I just think the multicolumn listbox would like to use as Excel.
Best regards.
03-10-2015 11:14 PM
Here is how you do what I said earlier to sum those two columns.
03-11-2015 04:45 AM
Thank you for your help.
In addition, by using a multi-column, I want to draw a graph.
Please check was added to the file.
Your answer will be a great help to me.
Best regard.
