I use a multicolumn listbox control to display values queried from a database. There is one column that needs to display more text than the other columns. So i want to set the default text size to a smaller size than the other columns. Up to now I changed the cells text size by clicking each cell individually and adjust the textsize. When i retrieve more records than the number of cells that I have adjusted, the text of the last rows still doesn't fit.
Is there a way to set the default text size per column ? (fe 1 column with text size 14 and the other columns text size 18)
