missing tags configuration file
Good evening
I have a cfp 2120. Unfortunately windows XP professional failed to boot and I have to install a new windows. I have set up the windows and labview 8.2 with sgp as DSC runtime. After I had installed all required software, an error message "Misssing Tags Configuration File" appeared.
Please help. Thanks in advanceMAXMissing Tagserror
(2,493 Views)
Hi Mahmoud,
LabVIEW 8.2 is not supported on Windows 7. The lowest version of LabVIEW you can run on a Windows 7 machine is LabVIEW 2009 SP1.
Windows Version Compatibility with LabVIEW
http://digital.ni.com/public.nsf/allkb/B972242574D4BB99862575A7007520CB
Andrew B.
Application Engineer
National Instruments.
http://www.ni.com/support
(2,439 Views)
Dear Andrew B.
Thanks a lot for your kind attention.
I will setup windows XP professional and try again.
I hope this error message disappear.
(2,428 Views)
