missing assembly manifest in .dll import
Hello Experts!
I am trying to import a .dll that I have created using visual studio 2010 sp1 (using c++) into labview. (lets say the super basic example described here:
Walkthrough: Creating and Using a Dynamic Link Library (C++)
Everything works fine when I am trying to do things in visual studio, I am even able to import the .dll in other .net applications. However, when I try to import this .dll into LabView, I get this error:
System.BadImageFormatException:
Could not load file or assembly 'C:\....\yourFile.dll' or one of its dependencies.
the module was expected to contain an assembly manifest. (Pls see attached screen shot.)LabViewImportcppdllError.PNG
I know right of the bat that I have to check my visual studio settings. I have done so, I have followed the steps described in below threads carefully and made sure that the manifest is embedded in the .dll.
http://stackoverflow.com/questions/12853502/manifest-for-my-own-native-dll
http://msdn.microsoft.com/en-us/library/ms235229%28v=vs.100%29.aspx
and here which describes how to embed it in a post process: http://msdn.microsoft.com/en-us/library/ms235591.aspx
http://msdn.microsoft.com/en-us/library/aa375649%28v=vs.85%29.aspx
However, I keep getting the same error when importing this .dll into LabView.
The thing is that I have developed tons of other .dlls in .net (all in C#) and never had any problem like this. So, defintely there is something obvious that I am missing! I would be happy if you could please help me with this?
(9,448 Views)
By the way, the target  .Net Framework version of the .dll is .net2.0
(9,435 Views)
Accepted by topic author Hatefk
redesigning the .dll as managed assembly solved this issue.
(9,428 Views)
