09-30-2010 12:51 AM
Hi
I want to find the frequency of an external signal.
How can i do that give me some idea or example.
Hari
09-30-2010 02:01 AM
Two usual ways:
Use the counter input. (good for clean signals, keeps the analog inputs free, doesn't need lot's of computation)
Got to Help / Find examples ... / Hardware Input and Output / Counter Measurements/ Digital Frequency /
Use the analog input and use signalprocessing vis to extract the tone frequency and phase
How does your signal look like?(sine,square, amplitude, offset, noise, ?? )
Frequency range?
Needed resolution?
09-30-2010 02:32 AM
Hi Henrik
I tried that example its working fine, but i need to diaplay that singnal in graph.
And one more is how can i start(Trigger) the measurement(frequency measurement).
Hari
09-30-2010 03:35 AM
If you need to capture the waveform look at the aquire waveform examples and add the
Owning Palette: Waveform Measurements VIs
Requires: Full Development System
Takes a signal in, finds the single tone with the highest amplitude or searches a specified frequency range, and returns the single tone frequency, amplitude, and phase. The input signal can be real or complex and single-channel or multichannel. Wire data to the time signal in input to determine the polymorphic instance to use or manually select the instance.
(copied from the help)
