08-06-2014 04:42 PM
I have some frequencies which I need to measure. Some signals are digital and some are analog.
I have a PXI-6040E DAQ which has both counters and analog inputs.
I heard that you can measure higher frequencies with the counters than with analog inputs.
What is the range of frequencies an analog input can determine versus a digital counter?
Where is the cutoff that you must absolutely use a digital counter to determine the frequency?
Is the cutoff different for different DAQ cards? Or is generally the same.
08-06-2014 04:59 PM
