Hi guys!
I was measuring DC voltages using ni-usb-6009 and I saw somthing weird.
There were two channels, chiannel 1 is -9.7V and channel 2 is around 0V and there was a 10k resistance between 0V voltage source and the ni device. Both virtual channels were differential.
After I measured them with rate of 1k/s and 20k/s, the weird thing happened (see the attachment). Channel 2 is really unstable compared to channel 1, but it was normal when I took away the 10k resistance.
Then why did it happene? Not sure if it's a ghosting effect or not, if it is, shouldn't it be just lower, in stead of being unstable?
Jude
