If you want to receive some proper help, you will have first to clean your code. In LabVIEW, wiring is always done from left to right. That's the first rule. And rule 2 state that if by accident you feel obliged to wire in the reverse direction, then you have to go to rule 1.
Avoid unnecessary bend, and so on...
Read the Chapter 6 Labview Style Guide of the LabVIEW development Guidelines in the LabVIEW help (Menu : Search the LabVIEW Bookshelf)
May be while rewiring your vi you will solve your problem...
Hope this helps... NO ! SURE this helps
Chilly Charly (aka CC)
E-List Master - Kudos glutton - Press the yellow button on the left...
