07-10-2014 01:15 AM
It’s so curious your project is working fine in my computer. The lvStorage.dll is showing in the dependencies list.
Since “lvStorage.dll” is missing in your computer, does the MDF.vi can be run without error alone?
If yes, please go ahead with the following steps.
1. Create Application(EXE)
2. Create installer (please include NI USI manually as we discussed above)
3. Build All
If the installer is build successfully, please check whether the installer work in other PC.
07-10-2014 01:40 AM
Yes, I can Run my VI without any error even though storage.dll is not present in my Project. Because lvStorage.llb is adding to my Dependencies list.
But, when I’m creating Installer in checking in other PC then its giving Error (Error Code 2564).
FYI, I did same installation process many times.
07-10-2014 01:55 AM
1. error -2564 represents that the file format can’t be supported on that computer, so could you check whether MDF DataPlugin is installed in other PC? If not, please install it.
2. I don’t know what you mean about “storage.dll is not present in my Project. Because lvStorage.llb is adding to my Dependencies list”.
The “lvStorage.dll” is included in dependencies list in my computer as following. Does your project have the same behavior?
07-10-2014 02:07 AM
In Development PC I installed MDF data plugin.
07-10-2014 02:13 AM
The MDF DataPlugin isn't added in the project when you create installer. So please install MDF DataPlugin in other PC and then try your application again.
07-10-2014 02:15 AM
I don’t want to install separately.
Is there is any way to add MDF Plugin to my installer??
07-10-2014 02:44 AM
I have added MDF data Plugin exe in advanced Tab “ Run executable at end of Installation”.
It’s working now but I don’t know is it correct way to add/not.
