12-09-2015 08:04 AM
Hello all,
Just started using a Windows10 PC and now when I try to run my Radio configuration tool which uses LabVIEW it is asking for lv80runtime.msi.
Q1: Can anyone help at all?
Best rgds.
Solved! Go to Solution.
12-09-2015 08:30 AM - edited 12-09-2015 08:30 AM
A1: Did you install the appropriate version of the LabVIEW run-time engine (e.g. 8.0) and the drivers required by the application? Did the application come with an installer that installs these for you?
12-09-2015 08:34 AM
Many thanks for your time.
I will go back to the developer as I have been using the disc on Windows XP & WIN7 machines.
(Perhaps I need the latest realease.)
Have a good day!!
