01-12-2009 08:56 AM
01-12-2009 09:00 AM
Hi mic_k86,
you can use a path constant, maybe the "temporary" or "default data" directory. With strip and build path you can then create the path you need.
Mike
01-13-2009 04:31 AM
Hi Mic_86,
You can refer to the examples in the labview file.Just type file in the search and should see several example on writ and read of LVM file.I attached one example for you.
Regards.
S.ahmad
Application engineer.
