01-06-2006 01:32 PM
01-06-2006 02:36 PM
You have a major problem with them as subVIs since you have not way to pass data from the main to them. None of the controls on your subVIs are wired to the connector pane. Aside from using something like global variables, that's the only way to pass data. You can greatly simplify your subVI by setting it up for only one instrument and not using a loop. Instead, make the session something that you pass. I've attached a modified write and main that shows what I mean.
I don't know what you mean by setting the instruments with configured settings. You already have a state and a button to do this.
01-07-2006 03:26 PM
01-09-2006 08:23 AM
1. To learn how to create a subVI, go to the on-line help and enter connector panes as the topic. Read it and click all of the links (especially the 'connector pane' one). You need to assign terminals.
You can put any graph you want on any tab simply by placing it there. You already have a graph on the Xtalk Plot tab so I don't understand what you're asking.
2. I'm not sure what you're asking. could you explain a little more. You also havne't included any of the subVIs and they would help me understand what you are trying to do.
3. There are numerous file write options. Look at the Waveform>File I/O palette and the File I/O palette.
01-09-2006 11:10 AM
1. I was able to create one for the 'load' event and it seems like it is working...I just hope it would set the instruments correctly. (plz see the attached)
2. Maybe I was not clear with my explanation of the problem. Please see the attached word file to see if that will be a better explanation of my intended goals. (subVIs will be attached on another reply)
3. How can I display "%xtalk vs. #aggressor?"
01-09-2006 11:10 AM
01-09-2006 11:28 AM
01-09-2006 11:49 AM
1. I just want to show those subVIs that are integral to xtalk calculation.
2. It is shown on the words doc...
X-axis: # of enabled (activated) aggressors. Y-axis:(%) xtalk value with each number of aggressor(s) enabled (activated).
this one looks a little tricky how to show after the initial waveform graph display.
01-09-2006 12:09 PM
01-09-2006 05:18 PM
Thanks for your response.
I just have a couple of concerns....
1. whether the waveforms will be accumulated for those aggressors that are enabled only.
(e.g. with 3 enabled, waveforms with 1-aggressor, 2-aggressors, 3-aggressors..I will have to try this out to find out what happens)
2. whether the load and save events can set the instruments correctly with desired parameters....
