10-07-2007 10:27 PM
I am getting the error...
VI version is later than the current LabVIEW version. An error occurred loading VI 'CleanupCallback.vi'. LabVIEW load error code 9: VI version (8.2) is newer than the LabVIEW version (8.2b23).
10-07-2007 10:56 PM
10-07-2007 11:14 PM
09-08-2008 02:33 AM
I have got the error. How do I downgrade the VI to 8.0 version? Initially this VI is created using 8.0 however, i tried to open it with 8.2. ever since, the error apppeared.
09-08-2008 10:25 AM
Please do not insert images into Word documents and then upload the Word documents. Contrary to what Microsoft may want, not everyone has Microsoft Office. You can upload images directly. Just make sure they're PNG, as those are small, as opposed to bloated BMP files.
When you opened it in 8.2 you saved it, therefore it converted it to 8.2. To downconvert it you need to open it with 8.2, and then select File -> Save for Previous Version.
09-09-2008 03:02 AM
thanks for your help!
i tried. but failed. by saving for previous version, does it save as a new VI? or does it overwrite the same old one?
09-09-2008 03:24 AM
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\LabVIEW Targets\FPGA\RIO\nirioDownload.vi
Cannot save VI from a toolkit to a previous version of LabVIEW.
this is what stated in the warning. Help..
09-09-2008 08:26 AM
No, you cannot save toolkits to a previous version. If the VI you are converting is not part of a toolkit, you should be okay - it's just a WARNING after all.
You would still need the correct version of the toolkit for the older version, however.
09-09-2008 08:59 AM
thanks!
but, does it mean that the library VI can be upgraded to a new version, but cannot be downconvert to previous version?
the solution is to re-intsall the library VI?
09-09-2008 09:24 AM
