02-27-2015 04:10 PM
My apology. Use config file processor for it. it's the same.
02-28-2015 03:57 PM
Are you really needing to allow for 1000 channels?
Why do you have all of that information in teh config file if the only thing you are pulling out are the channel names? If that is all you need, then just generate the names dynamically when you select the sensor(s)
And why are you adding a dimension to the array containing the channel names?
I am trying to grasp what your objective is but your code is a bit convoluted and you are not making it very clear what you are trying to do. For instance, you are applying Item Names to the list box contents after you use the values in the Listbox to index the arrays. Not making sense.
Go through a simple example. When you select ONLY sensor 1, wht do you expect to get at the end. If you select sensor 1 AND 2, what do you expect to get. Put it in a flow chart format that will put it in a linear flow of data.
03-02-2015 08:47 AM - last edited on 10-26-2015 04:41 PM by LiliMcDonald
There were some bad troubleshooting in the code. I updated it. see attached
Admin Note - VIs removed per user's request.
03-02-2015 10:39 AM
I fixed it, thank you all for your guidance and help
