12-31-2014 07:31 AM
Hello
I can not sleep because of lin communication. (ni 9866)
Now create a virtual simulation of the ecu.
Detours
1. When you create a LDF file, there can be set once the mode is not the Continue?
(Vi attachments, such as creating a DB can be selected.)
2. Use the attached LDF file now,
10ms when exporting the id2,
20ms, 30ms, 40ms, 50ms when you export the id3,
60ms, 70ms, 80ms, 90ms ttyae will export the id60 (3D HEX),
After repeatedly try to send something else.
However, when using the LDF File, the timing was not right.
As if each one beam naetda 50ms.
Ie, 50ms: id2
100ms, 150ms, 200ms, 250ms: id3 ................
Where Are there someone who can help me?
I think I can do everything you will need only a sample.
Ask any little advice.
12-31-2014 11:16 AM
Nothing you say makes any sense. Please provide significantly more context. You also talk about attachments, but I don't see any.
01-01-2015 10:57 PM
It looks like Google translate made that a bit hard to read.
Are you saying everything you try to send is taking five times longer than you expect it to take?
01-02-2015 01:31 AM - edited 01-02-2015 01:46 AM
01-06-2015 01:32 PM
If English is not your native language, please feel free to post in the non-English subforum. Translators usually don't work too well with engineering speak.
Is there a reason you need to make the database at runtime? Can you just make it using the Database Editor, and then reference that database when the application runs by name?
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
