limit string control to number of bytes
Is there a way to set the limit on the length of string control in number of bytes? I have a string control whose length is always going to be 3 bytes and I don't want the user to accidentally enter more bytes.
What I have done right now is have a value change event on the string and display only the 1st 3 bytes whenever the value change event occurs but I want to know if there is any direct way to set the limit on the number of bytes on the string control.
Ritesh
Message 1 of 8
(4,302 Views)
Yes, set the string control to update while typing, then create a value change event on the control that tests the length of the contents. This event will fire with each key stroke.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(4,287 Views)
Did you set the "update while typing" property to True so that you can delete extra characters immediately after they are added instead of after people type for a while?
Apart from doing that I don't know of a way, though.
Message 3 of 8
(4,284 Views)
Accepted by topic author LVCoder
This has been discussed many times in the past. For example look here.
Message 4 of 8
(4,279 Views)
And go give this idea a kudo: Option to Limit the Number of Characters in a String Control
GCentral
Message 5 of 8
(4,274 Views)
Another related idea would be to have a fixed lenght string datatype as described in this idea. 😄
Message 6 of 8
(4,267 Views)
No, update while typing is set so the event will fire with each key stroke.
Mike...
LabVIEW Champion
Message 7 of 8
(4,233 Views)
Thanks everyone!
I am already using "String value change" event to capture the change and then displaying only the 1st 3 bytes, but altenbach's answer is more elegant that it doesn't allow keystrokes event if the number of bytes have already reached the limit, so I accepted that as a solution.
I was only hoping to find a direct property of a string control to limit the number of bytes. It seems like the rquest has been submitted mutiple times so I did my part and kudoed those requests.
Message 8 of 8
(4,176 Views)
