03-19-2015 03:29 AM - edited 03-19-2015 03:31 AM
Hi friends,
I use periodic function.I would like to determine location corresponding any volt level inthe rising or falling edge of signal. For this, what can I do?
have a nice work
03-19-2015 07:36 AM
Look in the Signal Processing palette. There are all kinds of interesting functions in there. There is a Threshold Dector VI in the Signal Operation subpalette that might do what you want. You should also look in the Waveform Measure subpalette for some other functions that may do what you want.
03-20-2015 02:30 AM
Thanks. I use basic level trigger detection function. this function is determined location belonging to the first peak. What can I do to determine location belonging to the other peak?
03-20-2015 06:28 PM
Have you take a look at the Amplitude and Level Mesaurements VI. Here you can get the positive peak and negative peak of a signal.
David M.
