10-07-2014 05:15 AM
I am puzzled about how the labview timestamp works and whether the leap seconds are included in it or not.
In the link http://www.ni.com/white-paper/7900/en/
It clearly states that they are not: (i64) seconds since the epoch 01/01/1904 00:00:00.00 UTC (using the Gregorian calendar and ignoring leap seconds)
BUT if I convert the current time (which I understand is the time of Windows which includes the leap seconds) to a labview timestamp in seconds they seem to be in sync and not to have an offset of 25 or so seconds which are the leap seconds introduced since 1/1/1904
Example:
12:10:00 07/10/2014 -> 3495521400
Is there a way to demonstrate with a small vi that the leap seconds are or are not included in the labview timestamp?
thank you
Solved! Go to Solution.
10-07-2014 07:08 AM
Your test cleary states that the LabVIEW timestamp does not include leap seconds, otherwise the result would have been 3495521425.
Regards, Jens
10-07-2014 07:25 AM
Thank you Jens for the answer. I think I understand now.
Then this means that the labview time "jumps" a second every time there is a leap second, correct?
So if I want to know which is the number of seconds that actually passed since 1/1/1904 I should add the leap seconds to the labview timestamp?
Thanks again,
Theodoros
10-07-2014 07:45 AM - edited 10-07-2014 07:45 AM
Correct!
Regards, Jens
