08-24-2006 05:55 AM
08-24-2006 06:32 AM
08-24-2006 07:00 AM
Thanks for your fast response.
I used "insert into array" instead of "replace array subset". I hope that helps, havent tested it though.
Simon
08-24-2006 08:20 AM
I think it did the job, now the only limit to the size of the arrays is my memory.
Can do 2 * 50,000,000 array 32bit numbers - uses about 400Mbyte of ram and can run at full speed.
So I guess when insert into array is used the whole array has to be rewritten in the memory, whereas with replace array subset only the relevant cells are changed in the array already stored in the memory.
08-25-2006 07:51 AM
