11-28-2015 11:34 AM
I have a simple question. I have a sample data (64x64 pixels) of straight beam projection using gaussian function. The problem is how can I implement laplacian filter with the following kernel (3 x 3) : [ 0 -1 0 , -1 4 -1 , 0 -1 0] to the given data? Any examples which I can referred?
Thank you.
11-28-2015 11:44 AM
Applying a LaPlace filter is simply doing a convolution with the 3x3 kernel that you showed. Try LabVIEW "Help", "Convolution". Then try to write your own program, test it, and if you have further questions, post a followup question along with your VI.
